Bosch washer
  • #91181
    kaibart
    Hi all just wondering if anyone has had a fault on a Bosch w/m wae24063gb/30 fd 9412 605025 pump was blocked so I unblocked the pump and reset the error now the door lock wount engage I didn’t have a door lock on van to try but my concern is if the pump has overheated and taken module out? Any thoughts Kai :clown:
    #447347
    Re: Bosch washer
    if it has you should see the pump triac with a hole in it on the board also the old pump coil will have overheating marks on it (hopefully)
    kaibart
    Re: Bosch washer
    Machine is a nightmare to get out going back tomorrow will have a good look
    #447349
    Re: Bosch washer
    typical its always the awkward ones that give trouble
    kaibart
    Re: Bosch washer
    Turns out it was a door lock 😀 😀
