bosch wvf2402gb/01 dryer heater failed I replaced ok but customer says machine is over heating (dangerous !) I see a “tunnel kit” part no 480948 is listed with stats etc is this designed to sort out this problem? is this a common fault? I know someone out there will know! 😉
Did you have to uncouple the water supply when you did the repair previously?
Im wondering if the hot and cold pipes have been put on the wrong way round. Worth checking first.
fan was running ok I usually trip the door switch to check the air flow but didnt on this one as two toddlers were getting the way and “safety first ” going back tomorrow will keep you posted
