Bosch washer dryer
  • #53954
    maltheviking
    Sorry chaps/chapesses no model no yet.
    Bosch w/d with steam coming out of detergent drawer. I have cleaned build up of fluff out of dryer duct, fan ok, heaters ok, water valves ok.
    anyone come accross this or any ideas please.
    Mal
    #317859
    Re: Bosch washer dryer
    as with any condensor dryer of this type machine will breath as washing tumbles so you may get some condensation. there is no air inlet so air cannot continously get out. this should be no worse than putting machine on boil wash
    hope this helps
    nomadPaul
    There is a modified hose for some washer dryers but would need to have the full ENR number before i could confirm whether your’s is one of them. Its the small ‘U’ bend hose connecting the little condensor box to the big condensor container. The hose has been re-shaped to stop excessive drawer condensation/steam.
    And with the dryer duct , did you remove it to clean it or did you just access it from the top by removing the fan ? The normal build up is right at the bottom where the condensor duct joins the tub and normally only be completely removing the duct can you clean it fully .
    #317861
    maltheviking
    Just an update and future reference for anyone, model was a WVT126SGB/01
    Fault turned out to be a intermitant coil on the condensor valve, took 20 mins for it to fail 😥 5 mins later it was ok again. I new it all along :rolls:
