Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch washer dryer – draining even with drain pump filter and drain pipe open
- This topic has 8 replies, 2 voices, and was last updated 5 years ago by
Violet.
March 20, 2021 at 10:54 am #99314
Violet
ParticipantHi,
I have an error code E:36 -10 flashing on my Bosch washer/dryer, WDU28560GB. Basically it wont drain, I checked the drain pump filter and all fine but the water comes out very very slowly. The door eventually opened but there is a lot of water in the drum, that doesn’t seem to be going despite the pump filter and drain hose being open.
Before I call out an engineer, is there anything else I can do?
March 20, 2021 at 12:46 pm #475825electrofix
Moderatorif you have opened the filter with machine full and its only trickling out then you blockage is in the sump hose as it leaves the drum
March 20, 2021 at 2:33 pm #475826Violet
Participantelectrofix wrote:if you have opened the filter with machine full and its only trickling out then you blockage is in the sump hose as it leaves the drum
Thanks, I can hear it draining, then it stops and leaves a pool in the bottom with error E:36 -10, I called Bosch and they said it could be a problem with the Aqua Plus. As it’s so new I thought perhaps it would something more straight forward. I have googled that error and nothing comes up for it.
Is it difficult to check the sump hose? I don’t want to invalidate the warranty, but they can’t come out until Friday, with two children I hoped to be able to fix it before then.
March 20, 2021 at 3:37 pm #475827electrofix
Moderatorif it is blocked you would have something missing out of the wash
small socks, colour catchers, hankerchief etc
if the machine has water in it and you take out the filter, it should all drop out very very quickly. if it doesnt it has to be blocked
where is the machine plumbed into
sink waste or stantion pipe ?Dave
March 20, 2021 at 3:51 pm #475828Violet
Participantelectrofix wrote:if it is blocked you would have something missing out of the wash
To be honest I’m not that organised with the washing, I just threw in what was in the wash basket, so if a small item is missing I would have no idea.
I believe it’s attached to the sink waste, so the pipe that takes away the water hooks into a waste pipe under the sink.
I have checked these too.I did lift up the machine, but underneath is completely sealed unlike my old ones where you could see inside. There is a white plastic plate under what I am guessing is the sump pipe, hard to know and I can’t find any info online.
March 23, 2021 at 8:04 am #475829Violet
ParticipantI tried to run a quick wash to see if the water was draining at all and it isn’t. When opening the drain hose only a small amount comes out, so it’s full of water.
Where could a blockage be that is stopping the water coming out from drain hose and coin filter?
March 23, 2021 at 10:06 am #475830electrofix
Moderatorin the sump hose
March 23, 2021 at 3:04 pm #475831Violet
ParticipantThanks, as the bottom is sealed on this unit I guess I should wait for the engineer. I’m not sure how to access it on this model.
March 23, 2021 at 5:40 pm #475832electrofix
Moderatorthe front has to come off the machine so not easy
what you could do as a long shot is find a small mirror and a torch
remove the filter and inside where the filter comes out is a hole where the sump hose connects. angle the mirror and torch so you can see up the hose. You can then see if there is a sock stuck at the entrance to the filter that may be able pulled outDave
