Hi, I have a Bosch Washer/Dryer Model WVH28421GB. It lost power mid cycle recently. I, therefore, assumed it had fused. I was right, the fuse needed replacing. It then worked OK for several washes ( dryer not used ) then it lost power again. I don’t believe it is a fault with the socket because I used a different socket when I replaced the fuse. Any ideas what could be causing this? The machine is about 6 years old.
no idea what it is but if its blowing 13A fuses ( i assume thats the one you have in ) then before long you will destroy it as it can do damage as the fuse blows
No, it’s a 10A fuse. But I presume, as you say, it will do damage to the machine if I keep replacing the fuse only for it to blow. Time to get an engineer out I think.
