Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch washer dryer stops mid cycle
- This topic has 11 replies, 2 voices, and was last updated 12 years, 10 months ago by
2tMike.
July 1, 2013 at 5:11 pm #76065
2tMike
ParticipantBosch WKD28350 performs all mechanical functions but on a wash or drying cycle stops at random and the indicator panel goes off Then a regular clicking noise begins and continues until the programme selector is turned to off. Stopping seems unrelated to the part of a wash or drying cycle. If the machine is then powered off and back on after a time eventually the indicator panel comes back on and the cycle can be sometimes be resumed
July 1, 2013 at 5:25 pm #397115Martin
ParticipantRe: Bosch washer dryer stops mid cycle
I’m assuming you have checked the plug and wall socket first?
July 1, 2013 at 5:38 pm #3971162tMike
Yes, and powered from a different outlet with the same effect
July 1, 2013 at 5:54 pm #397117Martin
OK, now when the panel lights go out and the clicking noise starts, try opening the door? I’m thinking faulty door lock connection?
July 1, 2013 at 5:56 pm #3971182tMike
Door is locked securely at that stage and can only be opened by the manual overide pull
July 1, 2013 at 6:00 pm #3971192tMike
But you might have something there…in the ‘failed state’I’ve just pushed the door quite hard shut and the panel came live again and the cycle could be restarted. Might be coincidence so I’ll try again when it next stops
July 1, 2013 at 6:00 pm #397120Martin
Often a door interlock problem if not it’s looking like main PCB problems. 🙁
July 1, 2013 at 6:11 pm #3971212tMike
Sadly it was a coincidence, this time pushing on the door does nothing and the machine remains dead except for the clicking noise…
July 1, 2013 at 6:34 pm #397122Martin
2tMike wrote:and the machine remains dead except for the clicking noise…
And chances are with the lid off it is coming from the PCB maybe?
July 1, 2013 at 7:07 pm #3971232tMike
Starting to look very much that way…the clicking noise is clearly an intentional signal but I can’t see a reference to it anywhere or any error codes …I guess a PCB replacement is seriously expensive ?
July 1, 2013 at 7:16 pm #397124Martin
Not cheap for sure…check it out on Bosch’s spare parts website.
July 1, 2013 at 7:33 pm #3971252tMike
Just did…£187 ouch ….;((((
