bosch washer dryer timer stops when drying
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch washer dryer timer stops when drying
  • #67428
    richy
    hi model fd8805 enr wvd2452sgb/01 when the dryer is working and 30 minutes is selected the machine operates correctley but when it reaches 23 on the timer it stops .the display then shows a fan symbol.the fan and inlet cellenoids and heater test ok . ❓
    #367422
    Re: bosch washer dryer timer stops when drying
    The number you gave was NOT the model (ENr) number but just the Fabrication Date (FD)when it was made (in this case May 2008)…If you could give us the full ENr it would help us to help you. 😀
    #367423
    richy
    sorry enr wvd2452sgb/01
    #367424
    ? Stab in the dark – maybe fan has internal self-resetting toc in windings and is overheating for some reason then has reset by the time you test it?
    Mike.
