Bosch wvd2452gb/01 the door will lock when turned on and unlock after a couple of mins when turned off, I’ve tried as is says in the manual to hold the time delay button for 5secs but all it does is 2 beeps none of the buttons will do anything, is there a reset for these? The only problem I found was a blocked filter.
OK, so at the end of any programme the count down timer should show 0:01 and then the child lock must be deactivated otherwise the door CANNOT be opened. Only when the display shows -0- can the door be opened.
