Machine does wash programs with no problems
However if set on wash and autodry it shuts down with the display showing 1:57.
Door is open and machine will not respond to any buttons unless it is turned off and on again
If then just set to autodry it freezes with 1:26 on display in same manner
When first set to dry, the condenser valve opens and the drain pump runs. The valve then shuts and the fan starts up with the pump running every couple of minutes. However there is no power to the valve.
Element cuts in and out so NTC is controlling temp ok.
All megger readings on elements and motor are good.
Should the valve be open all through the drying stage or does it pulse?
Have been back and checked condenser and all is clear.
Water valve operates at start of dry cycle, then shuts off and the fan starts up.
Valve does not open again, there is voltage to it but neutral does not switch.
