bosch washer dryer wvd24525gb/01
Home Forums Public Support Forums Help And Support Washing Machine Help Forum bosch washer dryer wvd24525gb/01
Viewing 1 post (of 1 total)
  • #74359
    NigeS
    No heat on drying cycle
    New solenoid valve fitted as it was leaking
    Continuity across element
    225 volts element terminal to frame but zero across terminals suggesting no return path
    4.5k ohms across cold NTC
    Forgot to check cont from neutral side element to board, but is the neutral side switched at the board, and does the NTC determine the status of the live or neutral or both? Is this a board fault?
