bosch washer dryer wvd24525gb/01 no heat on dry cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum bosch washer dryer wvd24525gb/01 no heat on dry cycle
  • #74364
    Washdisher
    New inlet valve fitted as old one was leaking.
    Continuity across dryer element.
    225V from element to frame but zero volts across element terminals suggesting no return path.
    NTC cold resistance 4.6k ohms.
    Is the neutral side switched?
    Does this sound like a board fault?
    #391203
    Re: bosch washer dryer wvd24525gb/01 no heat on dry cycle
    Yes and yes! Though you make no mention of the TOC?
    #391204
    Washdisher
    And finally, any idea which of the two boards is likely to be at fault? Presumably whichever one incorporates the heater relays but any idea which this is.
    #391205
    The main power board as a rule, though I don’t recognise the model number you gave.
    #391206
    Washdisher
    Hi Martin,
    Thanks for that. In fact it’s a wvd2452’S’, not 5
    #391207
    Washdisher wrote:Thanks for that. In fact it’s a wvd2452’S’, not 5
    Nice! The power module just a tad over 160 quid on those. 🙁
    #391208
    Washdisher
    Think I’ll buy me a vented t dryer, Thanks for all your help.
    Derek
