Bosch washer dryer WVD2452SGB/02
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch washer dryer WVD2452SGB/02
  • #56828
    wefix-uk
    I have difficulty solving this job and I would really appreciate some help if anyone has come across this problem.
    The dryer would start and while I was there it would dry for 10 min and then ends the cycle even though I set it to run for an hour.
    I’ve replaced the NTC but it did not solve the problem.
    It does everything it is supposed to do while working – blow air, heats up, but it just won’t work for the time required.
    It has an auto setting also and I thought it may have a sensor for it, but i could not find one.
    Drago
    #329024
    peterjay
    Re: Bosch washer dryer WVD2452SGB/02
    check water valve if no water going in it will shut down as it cant condense
