customer says this machine is coming up e17/e18 when on dry whent today put on gentle dry for about ten minutes with the door open to check air flow ok it did jet a small amount of water into drum once in that period ,she say washing comes out wet through at the end i know fault code relates to a blockage or no water but cannot see any problem condenser looks clean corrigated hose clear not sure were to look next
