Bosch washer WAE24366GB/28 Dead
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch washer WAE24366GB/28 Dead
  • #76109
    johnnyhoz
    This washer stopped part way through a cycle customer said had about 40 minutes to go.
    power to board but no life at all. Apart from the board is there anything else on this model that can give this symptom ?
    Any advice greatfully recieved
    John
    #397284
    Re: Bosch washer WAE24366GB/28 Dead
    johnnyhoz wrote:Apart from the board is there anything else on this model that can give this symptom ?
    It does sound as though the board at least requires closer inspection to find out what might have blown it? Then check what component caused the fault (interlock, motor inlet valve etc etc)
    #397285
    johnnyhoz
    Thanks Martin, the customers already giping at the cost of the board and labour so probably won’t go head with the repair once I find out what caused the board falure.
    Trouble is in this area we have an argos end of line warehouse, they sell washing machines under £100, when people are pulling their belts in they don’t look long term,
    John
