Bosch washer WAS28466GB/10 Clearing Error Code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch washer WAS28466GB/10 Clearing Error Code
  • #86964
    subs
    FD8803
    This machine has a F43 error. Replaced brushes which were completely worn but the error won’t clear. I’m thinking unless I’m trying to clear the code incorrectly then maybe the motor has damaged the board. The motor seems to check out ok and there’s nothing obviously blown on board.
    I’m trying to clear the error by switching dial to 6 o’clock while holding the spin button, then continuing clockwise to 7 o’clock while holding the spin button for a further 5 seconds then releasing it and switching the dial back off.
    Any help please
    Subs
    #433531
    You got the reset procedure correct though you may need several attempts. Another sure way is to disconnect the motor first, reset then reconnect.
    #433532
    nomadPaul
    Re: Bosch washer WAS28466GB/10 Clearing Error Code
    Don’t hold the spin speed button until you’ve turned the dial to 6 o’clock. Once you’re at the 6 o’clock position then hold the spin speed button before turning one more click clockwise.
