Bosch washer WFK2200 fault code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch washer WFK2200 fault code
  • #56972
    boselecta
    WFK2200GB12
    About 15 min into any cycle the machine stops and the the ‘spin’ neon flashes with ‘1’ shows in the LED display?
    Brushes, pump, inlet valves and element ok, any ideas people, thanks
    #329425
    A1engineer
    Re: Bosch washer WFK2200 fault code
    sure its something to do with water intake, you said valves are ok therfor id check the pressure tubing doesnt have a slit or hole, it could be filling the the switch is registering as no water hense fault code.
