Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Bosch washer WFK2200GB/12 FD 7701 drum bearings
- This topic has 7 replies, 2 voices, and was last updated 11 years, 5 months ago by
Washdisher.
October 23, 2014 at 11:22 am #82747
Washdisher
ParticipantOriginal bearings ODs 52 and 40, and IDs 40 and 18.
I ordered non gen replacements form Qtex and they are much bigger – the OD of the larger bearing is 72mm. I checked with BHS and it seems this is correct. I’m at a loss. I know that the customer bought the machine reconditioned and she is under the impression that it is a bitsa, so is it possible that a bearing housing and drum assy was fitted from a different model?
Any thoughts/suggestions gratefully received.
Dez
October 23, 2014 at 4:02 pm #420715Martin
ParticipantRe: Bosch washer WFK2200GB/12 FD 7701 drum bearings
Qualtex Bearing Kit BKT76. 😀
October 23, 2014 at 7:25 pm #420716Washdisher
Hi Martin, Thanks for that, it’s the bearing kit I bought. Definitely looks like the bearings and housing etc fitted to my machine are from a different mod
October 24, 2014 at 6:52 am #420717Martin
I’ve always just taken the bearing number off the bearing sleeve and never resorted to measuring the OD/ID. What number is stamped on those old bearings an?way? A WFK2200GB/12 should have 6305ZZ and 6306ZZ.
October 24, 2014 at 8:40 am #420718Washdisher
Hi Martin,
The smaller one is a 6203zc3 and the larger one just says Poland. Actually my biggest problem is finding an appropriate seal.
October 24, 2014 at 11:15 am #420719Martin
Sounds very much like you need BKT77 then which has 6205zz & 1x 6203zz Bearings and 1x 32×52/78×8/14.8 Bearing Seal
November 6, 2014 at 7:21 pm #420720Washdisher
Hi Martin,
Thanks for getting back to me on this one but the customer decided to go with a new machine. I was quite relieved as the smaller bearing was a very loose fit in its’ housing. So much so that it pretty much dropped out when I removed the housing from the machine. A new housing is no longer available from Bosch and I would have felt very uncomfortable using the old one.
Cheers,
Dez
November 6, 2014 at 7:31 pm #420721Martin
My pleasure.
