been to this machine a month ago to give estimate for new suspension legs customer now wants me to do the work does this model have plastic pins that attatch the legs to the drum as i have a scrap 12mnth old machine that i was going to use the suspension of but it looks like the pins are moulded to the rear half and you would have to split outer drum to remove is it the same on above machine as i didnt look on my first visit if it is i need to re-think the job :boops:
I believe that you are supposed to drill out the pins with a great big long drill bit (forget the size)and use bolts and special washers that come with the kit.
Yeah, with a 13.2mm drill you drill off the spindle head to a depth of 30mm. (from the front) Press out the remains of the spindle to the rear then insert the new bolt kit (from the rear) 😀
