Re: Bosch Washer WFP3201 Error 005
Customer reported an error code of “10” previously. Had someone else out (I was on holiday) and they changed the pump (??) – then found a blowout on the rear (motor control) PCB (it’s an old machine, they are mounted up in the top if you remember) and patched it up. Worked for a while.
Yesterday I found a dry joint in their repair of the board, and I changed the carbons anyway as they were three quarters worn.
Customer wants me to get them a new PCB (I think the old one is beyond repair now) Hopefully that will sort it. (£160 plus VAT RP from BSH!!) Yes I told them it would be expensive!
(What is an “E10”?)
regards
