Bosch Washer WFP3300 F05 fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Washer WFP3300 F05 fault
  • #40562
    johnnyhoz
    The above washer beeps and flashes F05, checked carbons which still have lots of wear left, the comm looks in good condition. Tried known good replacement motor and tested continuity of the wires from the board to the motor but still getting same fault. Has anyone had a problem in the past with this model ? should I assume it’s the module ?
    John
    #266837
    Re: Bosch Washer WFP3300 F05 fault
    johnnyhoz wrote:should I assume it’s the module ?
    I wouldn’t, besides they’re to expensive to replace anyway as a rule. What I would say is that the modules on these are built like brick outhouses and unlikely to fail unless the armature goes down to earth?
    It’s usually the motor that’s the problem and a motor that has a bad earth fault will take the module with it. Close inspection of the PCB is advised of course. 😉
    #266838
    johnnyhoz
    Thanks for the advice Martin
    John
