Bosch Washer WFX2868GB won’t drain F04 – Help!!!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Washer WFX2868GB won’t drain F04 – Help!!!
Viewing 15 posts - 1 through 15 (of 15 total)
  • #42348
    Highlandreid
    Hi there can’t get the washing machine to drain (by running a cycle or selecting drain). So far I’ve checked grey waste hose, pump filter, large black waste (between drum and pump with the ball float) and nothing obstructing flow. I currently have the pump removed which is an Askoll M50 292029 0.22A 30W.
    My question is am I likely to have dead/faulty pump (I can’t see anything obstructing the impellor), or could the problem lie with the water level switch? I haven’t tried to remove the small ribbed black hose that runs up to the pressure switch or the small white plastic bottle that connects to the black waste – these both seems quite tight
    We did 5 loads of washing one after the other and it stopped working on the last one and hasn’t worked since.
    Please Help!!!!
    Den
    #273185
    nomadPaul
    What happens if you select the drain cycle when there’s water in the appliance ?
    Does the water drain ?
    Can you hear the pump running or is there just a faint hum coming from the pump ?
    Does the drain hose sit in a standpipe or connected under the sink ?
    #273186
    Highlandreid
    Re: Bosch Washer WFX2868GB won’t drain F04 – Help!!!
    Hi there
    With the washer full of water, and selecting drain, nothing happens for around 15 seconds then there is a slight hum then I can’t remember if it gets to the end or F04. Either way no water comes out of the waste hose
    It’s normally connected into a standpipe, although I’ve tried directly into the sink next to it and a bucket on the side.
    I’ve manually drained it twice, but still comes back to F04 halfway through the wash cycle or a rinse cycle.
    Any ideas??
    Den
    #273187
    With the machine empty, remove filter and, using a torch, look right back into the impellor and see if it’s jammed. Kirby grips, 5ps, hairbobbles and the like are all small enough to get through the filter and jam it.
    If it’s clear, check that the impellor moves correctly. It should move freely, then resist and “ping” over each quarter of a revolution. If it feels stiff, it’s knackered and will need replacing. P/no 144484 – spares@ukwhitegoods.co.uk will get you one promptly if required.
    Highlandreid
    Hi thanks for the reply.
    I’ve already removed the pump, there’s definately no blockages here and looking at it on my desk it doesn’t look like there’s anything wrapped around it. It seems to turn OK, i.e free, harder to turn, then free as you describe.
    Den
    #273189
    Test meter – you should get 190-230 ohms through the coil.
    Highlandreid
    Measured it as ~163 ohm.
    Time for a new pump?
    #273191
    Highlandreid
    Hi everyone bought new pump, fitted and everything working again. Thanks for all your help.
    The old pump was definately stiffer and didn’t have the same springyness as the new one.
    Cheers
    Den
    #273192
    dmccann
    Hi, havve the same problems as above – have checked the filter at the front, nothing there and check the spinning thing – no problems ther. Have taken off the big black hose with the ball and stopper and now cannot get it all back together.
    First question – was the pump expnsive
    Second – was it easy to fit
    and thirdly – know any good washing machine repairers? Derby area.
    #273193
    Pump was about £45 last time I checked. spares@ukwhitegoods.co.uk will be able to price it exactly and supply.
    Fitting is quite straight forward if you remove the plug and the front panel. Three screws for the panel, two for the door lock, release teh springbamd for the door seal and it will pull away. Pretty obvious from there when you can see everything.
    dmccann
    Thank you for the info but I think I will be calling an engineer. Can’t even get the black hose back on properly…..I may take up a new career in appliance engineering – though I have managed to break two nails so maybe not!!!
    #273195
    ruddock289
    I wondered if commenters can explain the behaviour of my Bosch WFX2868:
    F04 is displayed when the mc starts to drain. If switched to off, mains off then on again, then switched to spin > start, mc drains, spins, and clean washing can come out of mc.
    So F04 only occurs at end of a full wash cycle.
    My investigations continue.
    Any views appreciated.
    Thanks,
    Robin
    #273196
    Andy jones
    ruddock289 wrote:Hi,
    Thanks,
    Robin
    Have you checked its definitely heating ??
    #273197
    ruddock289
    Washing is being cleaned. Why do you ask?
    #273198
    Andy jones
    I’ve had a similar problem with Bosch machines before. I would definitely test heater just to eliminate that
    Worth a try and only takes 20 seconds to test
