Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch washer working fine but not draining ONLY when on drying cycle
- This topic has 3 replies, 4 voices, and was last updated 5 years, 11 months ago by
Chris Bell.
May 1, 2020 at 11:20 am #97556
Chris Bell
ParticipantHi All, I have a Bosch Serie6 washer dryer and it is washing perfectly fine, but when it is drying it does not drain and the clothes then come out soaking wet. The filter isn’t blocked and I’ve cleaned debris from the waste pipe, but really I wouldn’t have thought this to be an issue as the washing cycles are draining fine. Any help or comments appreciated here!
May 1, 2020 at 12:34 pm #468376iadom
ModeratorIt could be a worn or weakening pump. Can you see the pump impellor with the filter removed? You should be able to turn the impellor round in quarter turn ‘flicks’. Does the impellor appear to have any loose or side to side movements? The reason they sometimes fail on drying cycle is due to running for much longer and seizing up.
May 2, 2020 at 10:33 pm #468377andyjawa
ParticipantIf it not the pump. Just a thought! Is this the Bosch washer dryer that is made in China ( PRC ) like the Siemens version so about 3 years old? Have had one once when the dryer inlet valve does not shut off when the machine finshes on the drying cycle BUT DOES eventually shut off after about 10 mins, drip, 5secs, then drip again ect…. The valves are not cheap to buy ( though they really should be ) so you might want to prove this first by being around at the end of the drying cycle and turn the tap off and then immediately take your stuff out to try to prove the point. I got in a hell of a mess trying to sort the wretched one I had to repair until it occured to me because inlet valves do not normally screw-up in that fashion, usually they just drip feed into the machine forever until you turn the tap off.. If you do prove this be wary of the new replacement valve`s longlivity as my customer found out the hard way when the pox ridden new valve filled up the machine during the night on day 2 for no apparent reason and she got somewhat moist the following morning, every new valve should really be sold with a free snorkel!……horrible contraption ( though not as bad as their dishwashers )…..never worked on one again as I refuse to.
August 15, 2020 at 5:47 pm #468378Gokhk
ParticipantShould be a recall just a joke that they can fit such garbage in a supposed decent brand , someone at bosch making the wrong decisons for pennies !
