Sorry i dont have the model n/o i,ve got a call tomorrow cust doesnt know the model n/o she says it stops with 1 minute to go, she had somebody else who changed the door seal on it for a split he thought this would cure but it didnt, i can only assume he thoght it might water leaking onto the heater, any thoughts on where to lgo with this one cheers JJ
Well some of the dishwashers give a ‘one minute remaining’ indication with heater failure so that may be worth a look…other than that it may be an earth fault from the leak?
Was there today heater is okay no earth faults resistance okay, prev engineer replaced door seal for leaking and replaced terminal on heater wire, it had been leaking for sometime as it was in a garage, i had a look at the module and it looks like all that lovely water peeing down onto the heater terminlas has done for it. JJ
