model classixx 6
It keeps cutting out, the warning flashing light say its the water pressure but i’ve checked and the water is ok, i’ve cleaned the little filter where the water connection is, is there something else i’m missing from checking…thanks in advance…
just looking at the parts, this one looks like it, a twin water feed and it has a little clip in power supply…would this be the correct water inlet valve for the machine..
Dave in the UKW shop should be able to source you a pattern variant for your machine. An email to spares@ukwhitegoods.co.uk quoting the ENR and FD number will get the ball rolling.
