Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › bosch washing machine brush motor
- This topic has 16 replies, 6 voices, and was last updated 8 years, 9 months ago by
fasetester.
June 27, 2017 at 1:28 pm #91541
fasetester
ParticipantHave brush motor fitted new new brushes when I run it to bench test run ok clockwise when run anticlock wise it is sparking and making a crackling noise .
Removed brushes and checked only half of the brushes making contact on commutator would that be the reason for the sparking.
Don’t want to fry pcb when reinstalled what should I be checking on machine for damage after motor heater door switch wiring thanks fasetester
June 27, 2017 at 4:31 pm #448487Martin
ParticipantRe: bosch washing machine brush motor
Cheapy pattern brushes are they fase? Or are you running that motor flat out?
June 27, 2017 at 4:41 pm #448488fasetester
The lamnated Martin testing motor with no speed control is that the reason for sparking
June 27, 2017 at 5:58 pm #448489Martin
Brushes have to be ‘run in’ for a period at low speeds. 800 rpm drum speeds ideal.
June 27, 2017 at 7:36 pm #448490electrofix
ModeratorRe: bosch washing machine brush motor
been having problems with non gen brushes for a while
I now take the rear edge off the brush with sand paper before fitting otherwise the brush only contacts at the rear causing sparking
after fitting I run the brush to 800 or 1000 spin and listen in case one of them need a bit more off
after fitting I tell the customer to avoid heavy loads of towels and use 800 spin for 10 washes followed by 1000 for the next 5 to give bed in time
never had a board blow because of it
June 27, 2017 at 8:04 pm #448491iadom
I only use gen brushes and charge the correct price for them. 😉
June 28, 2017 at 9:18 am #448492jag-12
Bed them in using com stick
Always do this with any brushes when fitting and never had any problems except when com is on way outJune 28, 2017 at 9:39 am #448493iadom
Found the thick brown comm stick hard to find and the white chalky one to brittle, end up with several small useless pieces.
Have been using THIS recently and it cleans the comm really well. 8)
June 28, 2017 at 7:07 pm #448494kaibart
Well I’ve fitted a pair of cbn2222 on a wae28364 tonight and they sound better than the originals do
June 30, 2017 at 1:04 pm #448495fasetester
Thanks for all the replys when bench testing motor without speed control is there any way of controlling the speed of the motor to bed in brushes putting a load in the circuit .
And if I wanted to test pcb on the connections to motor which terminals should I get a reading on on the PCB and what resistance should I get and has any one built a basic speed controller to control motor speed so I can run the motor at a wash speed thanks fasetester
June 30, 2017 at 2:37 pm #448496Martin
Bench testing motors is pretty much a waste of time as the motor needs to be under load to check correctly especially when it comes to running in new brushes. Bench testing flat out and most motors will spark like a Roman candle with new brushes in.
Com sticks sort out the commutator only whereas carbons may need extra TLC to ensure even contact with the com. A fine curved-toothed file perfect for those jobs.
As has been said earlier, genuine brushes are by far the best fit and much less likely to sparkle 😀
June 30, 2017 at 8:47 pm #448497electrofix
used to bed in some of the old hoover motors with a car battery charger. wired up arm and field in series and connect. you can run for a few hours that way cant over speed at that voltage
June 30, 2017 at 11:55 pm #448498fasetester
Any one build there own test bench with speed control I know you can buy speed controls what about testing the motor block connector on the PCB what reading should I get and what range should be used thanks fasetester
July 1, 2017 at 9:04 am #448499iadom
Not sure about Martin but in all my long, nay very long time in the trade I have never ever ‘bench tested’ any motors.
Young Jim.
July 1, 2017 at 11:55 am #448500Martin
iadom wrote:Not sure about Martin but in all my long, nay very long time in the trade I have never ever ‘bench tested’ any motors.
No me neither, no point whatsoever. The only exception is workshop repairs to vacs, fan heaters, hair dryers and the odd tumble dryer. But then I, like Jim am old school 😉
But these days there must be hoards of Ebayers reclaiming motors from scrap machines, reconning them and ‘bench testing’ them, somehow, and knocking them out cheap. :rolls:
