Thanks don, I just wanted to update I re-read the bosh series4 manual and spotted a small print saying that settings will not be saved, I assume its the custom settings which I wanted.
So it means its going to be very tedious to keep adjusting spin and speed and other settings on every wash vs the Samsung washers which auto save your last programmed settings per program.
I did spot on the bosch series 6 they added a touch panel design with spin and speed separate buttons which would make it more easier rather then cycling through several pre-sets each time, might be the home connect range also but thanks good to know it supports on that model type also.
