Hi, customer says machine empties but wont do final spin unless she turns programmer around to spin, then it will? I’ve checked pressure vessel, pump filter and sink waste. water is getting away fine.Any ideas? Many Thanks.
Ashby :rolls:
Hi Alan, Thanks for your reply. it has new brushes in it. I sold it as a recon machine. I used the machine several times myself before i sold it. I never had any problems with it at all. I haven’t got an instruction manual for it though.
Ashby
I Have come across many Bosch magnetic pumps that behave erratically, Work fine one minuet, Jam the next. Set to drain them pump the on/off switch, If the pumps faulty this will usually get it to stop.
