Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Washing Machine Exxcel 1400 express
- This topic has 7 replies, 4 voices, and was last updated 12 years, 11 months ago by
James210.
May 20, 2013 at 8:37 pm #75508
James210
ParticipantHi all
I have a Bosch washing machine which has developed a fault – it starts the cycle normally, then it seems to stick on the “wash” cycle for about twice as long as it should – it counts down to one minute then sticks at one minute for ages. It does this on all programmes. It will eventually then go onto the spin cycle but I think its repeating the wash cycle – any ideas appreciated!!
Thanks!
May 20, 2013 at 9:09 pm #395154iadom
ModeratorRe: Bosch Washing Machine Exxcel 1400 express
Possibly a heat ( or lack of ) fault.
May 20, 2013 at 9:13 pm #395155James210
ParticipantRe: Bosch Washing Machine Exxcel 1400 express
Is it something thats fixable? Thanks
May 20, 2013 at 9:27 pm #395156iadom
Everything is ‘fixable’ with the right tools, correct parts, proper test equipment, electrical knowledge, and safe working practises. 😉
If the heater is not working the it could be a faulty heater, broken wiring or even a failure of the main pcb.
May 20, 2013 at 9:29 pm #395157James210
OK – if I re phrase the question…what is likely to be causing the fault? Heater element / thermostat?
May 20, 2013 at 9:50 pm #395158iadom
Edited my post whilst you where posting, it’s not the thermostat, there isn’t one for a start. 😉
June 19, 2013 at 7:48 pm #395159rcdm1876
I have this same issue with the same model of machine.
Cleaned and checked filter, which was pretty foul smelling (great thoughts of the cleanliness of clothing) but interestingly had 0 build up of any hairs or fur or such like.
I am wondering if its the drain pump?
The fact on all cycles its stops at 1 minute is a real pest as manually over riding it is a nuisance and we feel that the clothes havent been as ‘clean’ or as ‘dry’ as they should be when coming out.
Interestingly at 6minutes one time it shorted the whole house and had to reset the fuse board. I would therefore assume and guess this may be electronic module related, but from a bit of digging online it seems to be a common issue with this machine so would be good to see what others have had to do to address before jumping to any conclusions.
Guesswork on machines age is 6 years, as it was in the house we moved to which we have been in for just over 3 years. In frequent but not ridiculous use as just me and my partner.
June 20, 2013 at 8:12 am #395160Martin
rcdm1876 wrote:I am wondering if its the drain pump?
That’s the first and easiest place to start looking. Pumps and drain filters the first thing to cause problems. Access is very user friendly.
rcdm1876 wrote:Interestingly at 6minutes one time it shorted the whole house and had to reset the fuse board. I would therefore assume and guess this may be electronic module related,
I would get the test meter out and check the heater next if I were you! 😀
