Bosch washing machine Exxcel 7 wae24467uk/10 spin problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch washing machine Exxcel 7 wae24467uk/10 spin problem
  • #78820
    Binz1966
    Bosch Exxcel 7 WAE24467uk/10
    Machine is trying to spin but won’t
    All started when machine ‘made a noise’ and then the house electrics tripped.
    I changed the brushes in the motor for genuine ones, checked they moved freely, checked they were in the right way.
    Ohm tested across the terminals in pairs 1.5, 2.2 & 15.8
    Checked the drain, all water is pumped away, pump makes a bit of a noise, but impeller is free and pings round. No water left in machine.
    Checked on the following settings
    Quick wash – machine fills, drum tries to turn in both directions but doesn’t, it won’t spin, timer suddenly drops to 1, drum agitates a bit, pump drains machine.
    Spin cycle only – starts at 12, pump starts, drum tries to spin but doesn’t, timer drops to 1
    Any clues.
    #407024
    Re: Bosch washing machine Exxcel 7 wae24467uk/10 spin proble
    You are sure that the new carbon brushes are in correctly, yes?
    Binz1966
    Yes, brushes in the right way, checked twice
