Bosch washing machine failing to empty
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch washing machine failing to empty
  • #20689
    sezzzy
    Hello,
    Our Bosch washing machine:
    E-NR WFF200L GB/01
    FD 7901
    frequently stops with the ‘rinse’ & ‘spin/pump’ lights flashing.
    Sometimes it will rinse & spin to completion if we drain it manually and wipe round within the filter.
    We have checked the filter and pipework leading to the drain and there are no blockages.
    Any help would be gratefully received.
    Thanks in advance,
    Sarah
    #188033
    linrew
    Re: Bosch washing machine failing to empty
    hi
    spin + rinsing lights flashing mean pumping period greater than 6 mins
    usually this is a blocked pump but you say you have checked the filter
    double check the hoses to and from the pump just in case there is a blockage in them
    when the machine sticks is it full of water or empty?
    if it stops and it is empty it may be a pressure sensor problem, depending on your ability it may be worth calling en engineer.
    linrew
