Bosch washing machine fault
  • #72640
    qcarelsen
    I was wondering if anybody could help.
    I just changed the two modules in a Bosch washing machine, and replaced the brushes, but now we cannot change the temperature on the machine. It has a button on the console, as you press it the temperature goes up to 90 degrees and the then back down. Now it is stuck on 60 degrees
    #385136
    Re: Bosch washing machine fault
    ….and the Enr number of the machine is…….? :rolls:
    #385137
    qcarelsen
    WAS28466GB/05 enr number
    #385138
    By the way you should post questions of this nature in Trade Tech not General. Perhaps a mod may spot this and move it?
    But, anyway, can I just ask why you had to change TWO modules in the first place AND did you configure each correctly?
    #385139
    qcarelsen
    Bosch-WAS28466GB/05
    Hi guys, please help as this is doing my head in. Went to change a PCB on above machine today, I got the machine working fine, but there is another problem, if you press any of the other buttons it just changes the spin speed, I know it’s a calibration problem, but the little paper they give you with it to calibrate it does not make any sence at all, I have tried every thing but just couldn’t get it sorted, does any one know in English terms how to do this.
    Thanks so long.
    Quintin.
    #385140
    Re: Bosch-WAS28466GB/05
    What are you like? Two threads , same subject, both technical questions posted in General Trade….I don’t know.. :rolls:
    You can’t make sense of the configuration instructions? What does your little piece of paper say? Do share it with us as I feel sure we can work it out together. ( sadly I don’t have a copy of those instructions ) 😥
    #385141
    qcarelsen
    Hi Martin sorry about that, I think my partner whent on before while I was on the road, so don’t know what he asked for, will give info on this shortly
    #385142
    qcarelsen wrote:will give info on this shortly
    Please don’t open a third thread, just post it here and with any luck a mod will move it to Trade Tech (but I won’t hold my breath. 😐 😕 )
    #385143
    Oh, go on Martin please, about ten minutes should do it. 😛 😆
    #385144
    Picture of PCB and tech info attached if anyone can help.
    OK, I will try to explain other than what has already been written on those config instructions. You need to put in the 15 digit KD Code (aka Service Code) and that is 1,2,1,0,0,X,0,0,2,1,0,1,0,0 ,0,2 ( the X is not used by the way).
    Carry out the initial setup position,” close door, turn selector to position 0 etc” and then when you get to position 8 you can then start to put in the codes. Don’t forget, 15 codes = 15 positions on the dial, that’s the clue to solving this German puzzle. 😉
    #385146
    qcarelsen
    Thanks Martin, I think I finally got it, as you say the X is not used is that why you have got an extra 0 in the table of numbers that you wrote above.
    Thanks again.
    #385147
    qcarelsen
    Don’t worry , I think it was just a tipping error and I have got it now.
    Thanks again
