Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch washing machine fault code WIS24140GB 07 fault code
- This topic has 7 replies, 3 voices, and was last updated 13 years, 7 months ago by
boselecta.
September 3, 2012 at 2:58 pm #71286
boselecta
ParticipantSpin speed led’s illuminated 3 and 4
Programme flow led 4 illuminated.
Checked pump, motor element, but fault still shows
September 3, 2012 at 6:09 pm #380620electrofix
ModeratorRe: Bosch washing machine fault code WIS24140GB 07 fault cod
does this fault show on turn on or only when prog started?
( some bosch machines need resetting after fault or it wont clear )does it run any progs ie rinses spin etc
if it does run how long before it fails ?
September 3, 2012 at 9:16 pm #380621boselecta
ParticipantRe: Bosch washing machine fault code WIS24140GB 07 fault cod
Hi Dave,
The machine starts for a few mins then fault comes on. When the fault code has started the instantanious door lock just switches on and off and fault remains unless sitched off at mains.
What is the reset procedure for this range of machine?
September 4, 2012 at 10:31 am #380622electrofix
dont know with this range
on one range you set ptog to 6 0clock hold spin speed button and tunn prog 1 click clockwise then let go spin button turn off then on and try again but it may not work on thishave you tried all programmes ?
does the motor ever turn ?
does it stop about the time the motor should turn?
have you looked at pcb for bad solder joint ?
if you still stuck pm Nomad he seem to have bosch knowledge
September 4, 2012 at 2:11 pm #380623boselecta
Hi Dave,
Yes the motor does turn, I have checked the brushes, they seem ok, have not looked at pcb.
Thanks will try to contact Nomad
thanks again
September 4, 2012 at 6:48 pm #380624nomadPaul
Did you get my pm mate ?
September 5, 2012 at 9:32 pm #380625boselecta
thanks paul,
very helpfull, will try what you advised and let you know. 🙂September 20, 2012 at 12:58 am #380626boselecta
Thanks again Paul,
The interlock seemed to fix the problem. 😀 😀 -
