Bosch washing machine new brushes fitted
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch washing machine new brushes fitted
Viewing 15 posts - 1 through 15 (of 26 total)
  • #89228
    fasetester
    Bosch washing wfx3268gb replaced brushes motor not going not washing or spinning what would be the problem thanks fasetester
    #440688
    Re: Bosch washing machine new brushes fitted
    poss needs a reset
    fasetester
    Thanks Dave could you please tell me how to reset it thanks fasetester
    #440690
    the common Bosch reset is like this
    turn programme knob to 6 0 clock
    press and hold the button that changes the spin speed
    turn knob to 7 o clock
    now release the spin speed
    you may have to do it 2 or 3 times
    if it has not got a spin speed button then this reset wont work
    You don’t mention if it will still fill and drain?
    If it will drain then it doesn’t need a reset but it is more than likely the motor toc has blown, possibly even the main pcb. 🙁
    Have you checked the motor electrically?
    #440692
    fasetester
    Thanks Dave for your reply fasetester
    #440693
    fasetester
    Thanks Jim for your reply when removing the connector from motor 3 of the orange wires came away from the connector in the motor plug not sure which connection the go into fasetester
    #440694
    fasetester wrote:when removing the connector from motor 3 of the orange wires came away from the connector in the motor plug not sure which connection the go into fasetester
    You won’t be able to successfully reconnect fase. Better you replace the motor plug to control board wiring harness (Pt no. 00600111).
    (FYI : The positions of the broken three wires in that connector are mirrored by the same connector on the control board.)
    #440695
    fasetester
    Thanks Martin what resistance reading should I get from the motor between 2-3 20 ohm between 3-4 open between 4-5 5ohms between 5-6 o ohms between 6-7 o ohms top to bottom thanks fasetester
    #440696
    I’ve no clue fase, sorry. But the good news is that you have continuity across the pins so chances are the motor is OK. 🙂
    #440697
    fasetester
    Thanks Martin as Jim said the machine would fill pump out when selected spin program would only set to 1200 spin not able to select 1600 spin
    Would start on 12 min count down to 11min then jump to 1min stop removed PCB there is a sign something happened PCB blackened around diode near the triac
    Should there not be a fuse to protect the PCB fasetester
    #440698
    fasetester wrote:Should there not be a fuse to protect the PCB fasetester
    Sadly fase, no. 🙁
    Those clever Germans thought it best not to put an inline fuse in. They got the advice from the Italians who thought the British were stupid enough to think of fitting one on every machine. So collectively they conspired to rid the Brits of any manufacturing of whitegoods. And that’s where we find ourselves today, in Britain trying to fix foreign imported c r ap.
    Come the revolution the Brexit Brotherhood will fight them on the beaches AND in the skies. Meanwhile hold on tight, don’t drop your guard, show them you are made of stronger stuff!
    #440699
    fasetester
    What is the most likely component to have blown on this PCB to affect the motor action I have tested the diodes around where the the board is blacked only getting meter reading one way on diodes .
    There is 2 black cinder cap not domed on top 2 blue rectangular components small square coil 4 resistors one blue round component .
    Then the triac how can you tell which is T1 T2 G when testing thanks case tester
    #440700
    first make sure your motor is ok
    since the most common failure is in the brush circuit try this
    remove motor plug
    put one meter lead on one of the brushes. then touch every connection on the motor motor plug connection. you should get a reading on 2 of them. one will read 0 ohms and the other will be a low ohm reading
    …….and did you get round to replacing the motor to PCB lead?
