Bosch Washing machine not running program after tripping RCD
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Washing machine not running program after tripping RCD
  • #101649
    steveb21
    Bosch Classixx Vario Perfect – WAE28166GB
    The machine tripped the RCD whilst running a cycle. Since then it will not start any programs.
    When pressing start the buttons light turns solid (as it should) but the machine does nothing else. At this point it should start drawing water in.
    No flashing error lights/codes (this model does not have a digital display)
    Door switch has been swapped out – no change
    Water inlet has been disconnected and has good water flow
    Any one having guidance on which areas i should be checking next?
    Pressure switch?
    Inlet valve?
    Drain pump?
    Many thanks.
    Steve
    #485567
    think i would be removing the pcb and looking for damage
    steveb21
    electrofix wrote:think i would be removing the pcb and looking for damage
    Hi Dave
    Is this the PCB user interface board? Are you aware how many PCBs there are on this machine?
    #485569
    all board are at the top behind knobs
    am expecting a track to have blown for some reason as something shorted out
    steveb21
    Just stripping it down, have a screw thats seized up. Will report back once i get to view the PCB.
    Thank you.
    #485571
    steveb21
    You were right, something has blown as there is a clear visible burn mark on the white plastic (near the round dial area).
    Two PCBs.
    1. Large PCB where i can see a burn mark on the board
    2. User input PCB which controls the buttons on the front face
    Is it a simple case of replacing the board with a like for like?
    I took photos however the site will not let me upload as my upload limit is too low.
    #485572
    wish it was that simple
    boards dont blow for no reason, another component in the machine has popped it. the chances are if you replace the board it will destroy that too
    to post pics , host pics on another site like google pics and post a public link
    steveb21
    https://photos.app.goo.gl/y2CH7UAqma3gdcDp6
    the area where the damage is appears to be coming from the 3 pin type connector with the grey wires. I will chase back to see which component it is connected to.
    #485574
    well there is a blown triac as well
