Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch washing machine not wash or spin model classixx 1000 e
- This topic has 22 replies, 4 voices, and was last updated 8 years, 5 months ago by
fasetester.
November 21, 2017 at 10:44 pm #451614
ModeratorRe: Bosch washing machine not wash or spin model classixx 10
yes if board power supply failed it would be dead
November 22, 2017 at 12:18 pm #451615fasetester
ParticipantRe: Bosch washing machine not wash or spin model classixx 10
Thank for your reply in your experience Dave what usually are the components that causes failure in both wash and spin would the tryic cause this failure is there a separate wireing harness supplying power into to the board. To control the motor and is there a fuse in the board that protect the motor thanks fasetester
November 23, 2017 at 2:13 pm #451616fasetester
Any BSH engineer s have experience of this fault want to reply to my last post or add anything thanks fasetester
November 23, 2017 at 2:49 pm #451617Martin
Any BSH engineer could only guess at what fails on the control board. They only change the board and don’t get down to component replacement or testing. If it don’t work they throw one in and cross fingers.
As to what can cause no power to the motor then it’s either a relay, triac, capacitor or resister failing. The more likely of those is the relay.
November 24, 2017 at 2:32 pm #451618fasetester
Thank Martin for your reply is their some washing machines will not turn tub unless the have a load .
Does this apply to Bosch machines fasetester
November 24, 2017 at 3:18 pm #451619electrofix
tub will turn regardless of load
fault could be
motor
wiring harnesspcb faults :- triac, relays, main computer chip or blown tracks
November 24, 2017 at 5:06 pm #451620timdowning
Fase, Is all this a wind up?
November 25, 2017 at 2:03 pm #451621fasetester
No Tim just trying to improve my strike rate on pcb repairs if you want to gain more knowledge ask questions
Can’t find a fault like a short that would have damaged the PCB thank again for all the replys .
