Bosch washing machine not wash or spin model classixx 1000 e
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch washing machine not wash or spin model classixx 1000 e
Viewing 15 posts - 1 through 15 (of 23 total)
  • #92572
    fasetester
    This machine will not wash or spin checked pump motor brushes checked connections check pressure switch removed hoses to pump was blocked with cement cleaned out as best I could pressure hose was blocked unblocked reconnected still not working any pointers thanks fasetester
    #451600
    fasetester
    Re: Bosch washing machine not wash or spin model classixx 10
    Model E_nr wfo2866GB/01FD8405 604179 this might help
    #451601
    Connecting lead from motor to module probably has broken at the motor end? If so order and fit new lead is the favourite option rather than trying to reconnect.
    #451602
    fasetester
    Thanks Martin for your reply
    Could someone please inform me should the spin selection knob spin round freely or should it click around to select the spin speeds thanks
    #451603
    It does click from one setting to another though if there is no motor action whatsoever that control has no bearing on the problem.
    #451604
    fasetester
    Ok Martin thanks it does not click it just spins around does it just pull off or does it have to be released from the back of the back of the control panel
    #451605
    release from rear
    if you select off position do the light go out ?
    trying to see if its snapped or not. losing the click is not a big problem as long as its selecting correct programmes
    timdowning
    I think he is talking just about the spin knob not the programme selector…
    #451607
    fasetester wrote:does it just pull off or does it have to be released from the back of the back of the control panel
    Ignore the spin control Fase, that is not the problem here, honest. It has fuff all to do with the motor not turning. 😉
    #451608
    fasetester
    thank all for your replies checked harness from pcb to motor all seems ok getting continuity at all connections
    #451609
    if you select a spin prog what happens
    I expect pump to run for a while then if you listen to the panel relays will click to start motor
    does this happen and motor fails
    fasetester
    When spin is selected it just keep pumping clock counts down then goes 0 and stops can’t here any clicks or sound from pcb thanks
    #451611
    well if it was a motor or wiring prob of any kind relays would still click#
    they can be hard to hear I sometimes have to put my ear to the panel to hear them or you could disconnect pump to silence it
    if no click sounds like a board prob
    assume you have checked motor tacho for continuity
    dave
    #451612
    fasetester
    Thanks Dave for your reply if the relay is not switching what is the most likely components on the PCB to have stopped working other that domed capactors to effect both wash and spin .
    I have come across Bosch motors with burnt out brushes that have damaged the PCB thanks fasetester
    #451613
    fasetester
    no one have any information what to check on the pcb for no motor on wash or spin is there any components that is known to causing this fault that i can test if nothing looks damaged would i be right in thinking that if there was no power coming in to the board the machine would be dead thanks fasetester
