Bosch Washing machine rust already?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Washing machine rust already?
  • #58274
    mstar
    Hi ppl,
    This might sound daft but i noticed on my Washing machine model: WAE24467 some rust around the door lock on the machine itself.
    Is this normal? i only had it 2years and 2 months!! can i ring Bosch and tell them? i cnt understand why? 😕
    I suspect they will charge and tell me to take out their D&G warrenty so if it gets worser they come and i suspect replace the front of the washing machine??
    #333942
    helo_75
    d&g dont cover corrossion so it would be a waste of money
    not many manufacturers do either, in or outside of warranty
    wouldnt expect it to be cheap either
    but… i gotta ask.. are you positive its rust? have u tried to clean it off?
    #333943
    mstar
    Re: Bosch Washing machine rust already?
    well its like a bubbling on the paint on the machine surface itself where the door catch is. So is there anything i can do, surely its a fault with the painting/metal as i have other appliances and they have no sign of it?
    [/img]
    #333944
    CJAPeterborough
    Without a picture then its hard to judge but if it was me I would look around
    in the garage for a bottle of rust eater and some touch up paint.
    With the door closed I doubt you will see much?
    I doubt the performance of the machine would suffer even long term.
    Whats the FD number re age of the machine?
    #333945
    mstar
    Whats FD number?
    the machine i got in Aug 2008 from a large high street retailer.
    #333946
    CJAPeterborough
    The Fd number should be on the rear plate/inside door trim next to/below the
    WAE model code it usually begins with 8XXX
    This will give the info re manufacturing date etc
