Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch washing machine taking too long
- This topic has 4 replies, 3 voices, and was last updated 19 years ago by
DentedPorsche.
March 26, 2007 at 5:22 pm #26150
DentedPorsche
ParticipantHiyas,
Bosch WF02466GB/07 washing machine giving me some headaches.
Customer complained it was taking too long to do a wash. Clothes sometimes coming out very creased or stretched.
Heater tests ok as does the pressure switch and system.
PCB has been changed and configured as per the supplied sheet and now the machine won’t take in water on programme 1 and still takes too long etc.
Anyone got any ideas and/or technical info on this machine?Thanks
BrianMarch 27, 2007 at 4:24 pm #208973DentedPorsche
ParticipantRe: Bosch washing machine taking too long
Still looking for help on this one. 🙁
Any ideas?Thanks
BrianMarch 27, 2007 at 5:34 pm #208974nomadPaul
what does it do on position 1 ? if it just pumps , the selector switch may have been put on 180degrees out of position . As to the wash times….if the clothes are stretched/creased…could it be overheating ? Maybe the NTC sensor has gone faulty and causing the water to heat to high. This could account for the longer times as well. Just a guess though
March 28, 2007 at 7:08 am #208975Martin
DentedPorsche wrote:PCB has been changed and configured as per the supplied sheet and now the machine won’t take in water on programme 1 and still takes too long etc.
Bit of an odd one you got there Brian? Why did you change to PCB? Was the fault there before you changed it? Are you sure the dip switches are set correctly? Is the inlet valve open circuit? 😕
March 28, 2007 at 6:18 pm #208976DentedPorsche
Hi Martin,
It’s the usual thing, I’ve inherited the job and I’m the fifth engineer to look at it.
It’s a cold fill only machine so no problem with the inlet valve.
Having spoke to the previous engineers it appears that the original fault was that it was taking hours to do any wash, since the pcb was replaced (3rd engineer) it now has additional problems.
I’ll take along a thermistor and check that the knob hasn’t been put on 180 degrees out. I’m also trying to get my hands on the original pcb.
I’ve also had an email from Greg with the test data so hopefully I’ll be able to figure this one out.
I really have to learn how to say “no” when I’m asked to help out :rolls:Brian
