Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Washing Machine WAE digital Fault Code E6
- This topic has 4 replies, 3 voices, and was last updated 13 years, 1 month ago by
bri-c.
March 12, 2013 at 9:19 pm #74531
bri-c
ParticipantHi, My Bosch washing machine will not pump out / drain the water after wash cycle & is showing E6 in the display. Thus far (before finding you guys)I have drained the water out, checked the main motor brushes, cleaned out a very clogged outlet from the pump, all to no avail. All help & advice greatly appreciated.
(Machine data is WAE 24260GB11, FD8612053626, WCM41.Best regards, 🙂
Brian C, Sussex.March 12, 2013 at 9:52 pm #391925Martin
ParticipantRe: Bosch Washing Machine WAE digital Fault Code E6
Check and double check the drain hose outlet, the pump and the sump hose to the drain filter. You’ve got a blockage there somewhere. If there is any lateral movement with the pump Impellor then the pump is clapped and needs replacing. One or all of the above will sort the E6 error. 😉
March 12, 2013 at 11:51 pm #391926kwatt
KeymasterRe: Bosch Washing Machine WAE digital Fault Code E6
And, further to Martin’s sound advice, the unashamed plug is that there are two drain pumps available for that machine…
The pukka Bosch one which is expensive here:
http://shop.ukwhitegoods.co.uk/144192-b … chine-pump
And the considerably cheaper “pattern” or compatible here:
http://shop.ukwhitegoods.co.uk/pmp253-b … chine-pump
But of course, if you’re not up to messing about with it and just want someone to come and fix it for you, you can find a local repairer here:
http://www.ukwhitegoods.co.uk/search/fi … ineer.html
We do like to try. 😉
March 13, 2013 at 9:23 pm #391927bri-c
Thanks fellas, I will check it all out, & get back to you – the pump impellor feelt really bizzare & very wobbly when I had a look at it – guess this may be the culprit, but I will let you know Tmoz. Have to get it fixed pronto as we are already knee deep in dirty washing!
Thanks for your help,Bri.
March 19, 2013 at 9:33 pm #391928bri-c
Fitted the new pump which turned up from whitegoods today, It all works – thanks to you all the washing mountain is now slowly subsiding.
Once again, thanks for your help – you were brilliant.Bri C.
