Hi.
Can anybody advise on the above washing machine? It’s the first time I’ve worked on the new WAJ range and this one is coming up with error code E:05 – 10..
It errors as soon as you turn the dial and beeps 4 times the display shows E:05 then goes blank then – 10 and repeats.
Thnaks.
Thanks for the info. Went back to this with a bit more time. Unplugged it tested everything I could found nothing so plugged it back in and the code had gone and everything is fine??????? Strange.
