BOSCH WASHING MACHINE WAP28360GB/14
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries BOSCH WASHING MACHINE WAP28360GB/14
  • #84957
    blackandwhites
    Don’t usually see these machines but I have been out to the above washing machine which has no motor action.It sounds like the relay is working(at least I can here it clicking),but there is no motor action.
    The motor is an induction motor.Is this a common component to fail on these machines.
    If the pcb needs to be replaced,does it need to be reconfigured?
    Thanks.
    #427264
    blackandwhites wrote:If the pcb needs to be replaced,does it need to be reconfigured?
    Neither the Power Module or the Inverter need configuring. The Inverter more likely to have failed than the Power Module. ( I’ve no idea which “pcb” you refer to?)
