Bosch Washing Machine WAQ284619B/12 Error Code E:34
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Washing Machine WAQ284619B/12 Error Code E:34
  • #88601
    treadwater1
    The problem emerged a few weeks ago, I tried a few different things after getting an E:34 code, none worked.
    Did a bit of digging online and worked out the E:34 code was something to do with the door lock. So i got a new lock and fitted it, at first it didn’t respond at all and then 40 seconds later the E:34 code came up again, so I’m guessing it isn’t the actual lock but the wiring going from the lock to the electric board
    Any clues how to fix it?
    Cheers
    #438718
    Re: Bosch Washing Machine WAQ284619B/12 Error Code E:34
    is the door locking at all ?
    treadwater1
    The door isn’t locking in, usually you hear a clicking sound a second after you press the start button.
    I shut the door, the light that indicates the door is shut comes on, I then press the start button and get the e:34 message. As far as I can tell there’s no problem with the handle mechanism
    #438720
    Almost certain to be a faulty Door Interlock. A replacement is part no: 00633765
    #438721
    treadwater1
    Thanks Martin, I bought and fitted a new lock earlier this week but no joy, must be something else
    #438722
    just as a long shot i take it the lock you fitted matched the part number martin posted above
    treadwater1
    Yes it was exactly the same as the original
    #438724
    You’ll probably have to remove the error code from its memory before it’ll behave.
    #438725
    treadwater1
    How do I do that? I’ve tried doing a reset but it hasn’t worked
