Bosch washing machine. WFR 2860 confused about models.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch washing machine. WFR 2860 confused about models.
  • #27590
    venn
    I need to replace my Bosch Maxx WFR 2460 and have looked at the WFL 2680 which seems to be the same machine with faster spin. BUT the 2680 seems to come in different models like the IT and excell versions. What is the difference when the model number is the same. Is the excell WFR 3267 a much better machine or is it only the spin speed. I seem to be stuck with old models of Bosch as the new models don’t have a child lock which prevents programme change when the machine is running and the washing times are longer.
    I’d be grateful for any advice,
    #214806
    nomadPaul
    Re: Bosch washing machine. WFR 2860 confused about models.
    you must be confused Venn…you’ve put it on the dishwasher forum 😀
    #214807
    Moved, 😉
    #214808
    venn
    Whoops. That is what happens with 2 year old twins, plus a muddy boy and no washing machine ! Will try again.
    #214809
    Simon46
    Out of interest what is the fault with the wfr2460?
    Regards
    Simon
    #214810
    venn
    There are 2 faults with it. The latest is “pump Blocked” in the display and the pump does not stop even when the water is gone.
    The second is a longstanding problem where the machine is unable to end the fluffing up cycle and has to be stopped with the red ring pull emergency stop every time.
    The two may be connected with a fault in the control system because it has been getting harder to trick the machine programming into restarting a new programme.
    I think the repair money may be best put towards a newer model, but it seems I cannot have a brand new Bosch with a child lock that stops mid cycle programme changes.
    So that’s why I’d like to know how a model can have one reference number WFR 2860, but seems to exist in different versions.
    Or is there a better, fast, child proof Bosch out there.
