Bosch Washing Machine WFR 2860 spin issue
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Washing Machine WFR 2860 spin issue
  • #65545
    clairol
    Bosch Washing Machine WFR 2860 works normally, washes, spins fine on all cycles except the rinse or spin cycles where it will no longer spin up to a reasonable speed. Starts to spin and then just stops. Spin works fine on all other cycles. Have tried more or less in the drum but has no impact.
    #360941
    Re: Bosch Washing Machine WFR 2860 spin issue
    Most probable reason is that the internal drain pipework could well be gunged-up with years of detritus and limescale. In effect its arteries are restricted meaning that it takes too long to drain which results in the interval spin between rinses ‘timing-out’.
