Bosch washing machine will not start
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch washing machine will not start
  • #69948
    LittleMan
    Hi i have 3 machines with the same fault Bosch wae24469gb/19 select program [any program]comes up 12 then goes to 0 door lock flashing. 2 wis24140gb/07 will not select any program. 3 was32466gb/05 the same will not select a program. Hope some one will tell me what it is and that its a silly fault.Thanks Les
    #376535
    LittleMan wrote:comes up 12
    12?…..error code you mean?………all got motor probs I would imagine?…what have you checked so far anyway?
    #376536
    LittleMan
    Re: Bosch washing machine will not start
    cmes up 12 then 0 in the LED only on WAE24469gb/19 all the others do not have a LED.I have looked at the motor brushes but not removed them also tested drain pump and door lock .If its a motor fault will it stop you from selecting any program Les
    #376537
    LittleMan wrote: If its a motor fault will it stop you from selecting any program
    As you know, all electronic controlled programmers ‘self check’ before proceeding. Therefore things like duff motor brushes will cause not to proceed…. 😉
    #376538
    LittleMan
    Thanks will change them Les
