Bosch washing machine wont take in water
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch washing machine wont take in water
  • #101115
    slyp98
    This one is 3yrs old , WAT286H0GB_34
    powers up select program, start , no water coming through, i changed the inlet valves , 140 yo yo still nothing , power going to valves , but i see theres a block connector missing from the side of the valve block , one molex connector goes to the aqua stop the other is a connection is a black plastic ring around the valve body , funnily the molex connector fits both connections , but why is there only 1 ? Any ides guys cheers k
    #483421
    by the looks of the valve it has a double valve system. one on the end of the hose
    can see 2 mol connectors on the hose. one will feed valve at the end of the hose the other will be the input sensor
    grooster
    Yes, ive had a few. Its the aqua stop attached to the tap thats open circuit. Its comes complete as aquastop, hose and valves.
