Bosch washing machine – won’t turn on
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch washing machine – won’t turn on
  • #88662
    wotwasher
    Bosch Avantixx 6 Varioperfect
    WAE24366GB
    5 years old
    Average use
    Happy with Bosch as washed well and no problems until recently: found that on a 2nd load of washing it had stopped mid cycle, water was still in the drum and no lights were operational on the control panel.
    Emptied water and checked that nothing clogging up filter. Able to open up and found washing was still covered in detergent. Checked that socket was working and checked plug (replaced with new fuse) – neither of these were at fault.
    So now I have a washing machine that will not turn on, is this repairable? Or should I be looking for a new machine?
    If the latter I only have a budget of £300 and having read some of the articles on this website. I’m confused. Should I go for another Bosch (I had hoped it would last a little longer if this is the end of it)? Or should I go for something like a Zanussi, knowing that it won’t last as long but will be a bit cheaper?!
    Many thanks
    #438935
    Re: Bosch washing machine – won’t turn on
    sounds like a panel problem
    its prob repairable sounds like it may be the panel power supply or need a new panel
    you could get someone with the knowledge to look or
    remove your panel and contact
    http://www.qer.biz/Lists.htm
