well its not a main timer problem although you can never rule out 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} that its survived, i would think 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} chance its ok
so your down to motor or inverter
check where the track is going, if its going to a motor phase connection then the motor is suspect for poss damage or cause
if its on the live in then its a possible rectifier problem. If you did a check on the bridge rectifier you may well find it short
either way you have had high current flow you just need to figure out to where. look for other tracks where the paint has come off but not blown. A clear indication they have got hot through high current
