SGS65L22GB/07
On some fill cycles, about a cup of water is ejected from the top of the matrix/heat exchanger. Float assembly has been replaced. I would be grateful for some suggestions as to why this happens. Thanks.
It has only recently started doing this, so unless the water pressure has changed… I feel it is a control issue. It only happens at some points in the programme, for example the last fill at the end of test programme P1. The inlet valve energises 3-4 times in 1 sec intervals (approx), beyond the float/diaphragm control switching. The behaviour seems consistant and no errors are reported.
