Bosch WAW28560GB/01 Washing Machine Door Interlock/Other fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WAW28560GB/01 Washing Machine Door Interlock/Other fault
  • #98551
    jontymox
    Good evening all,
    The above W/M has a problem, which may be well known to some….?
    Essentially, upon selecting a programme and pressing start, the m/c locks, and then quickly unlocks the door, resulting in a non start.
    Intermittently, it will start and continue with a programme.
    I’ve renewed the door interlock, and the fault remains…. i.e. locks, unlocks, locks, unlocks…..
    Do I suspect the operating module. or should I perhaps be looking at the pressure switch etc?
    Kind regards,
    jonty
    #472805
    think i saw somewhere on here a member saying they had problems with the wiring harness from lock to board. might be an idea to check connections
    jontymox
    Struggling with this one as well!
    Wiring connections, and continuity fine between power module & door interlock.
    The suspect power module is out of stock with Bosch UK, and they cannot provide a time scale for obtaining from Germany/Europe!
    So, at the moment customer says she is happy persevering with washing machine, as she can get it to work after several attempts…
